Getting Error: java.sql.BatchUpdateException: Duplicate entry 'e05dd3c82b45e100b641825319da15e4' for key 'PRIMARY'
m_servicenow
When i m submitting PC ordering through record producer always i m getting following
Error which is in screenshot...
Find the attached screenshot....
Thanks in advances..
12 REPLIES 12
pritam38
You must have written current.update() in one of your business rule.
I have faced the same in the past.
Please check and if it is there, make business rule before insert/update and remove the current.update() from the same.
pritam
andymcdonald
Mega Guru
In case this helps someone...I was searching this issue last week.   It turned out the root cause in my case was that I was trying to update a record that was not in the table on which I had defined my GlideRecord.   You'd think there would be a better error message for this, but nope...
ramprasathpt
This KB might be helpful
https://hi.service-now.com/kb_view.do?sysparm_article=KB0716513
Thank you,
Ramprasath P Thirubalan.
