Have anyone done venafi integration with ServiceNow?
Arun Prasanth
Mega Contributor
Have anyone done venafi integration with ServiceNow, to maintain the SSL/TLS certificates in CMDB? Please advise if you have any experience towards it
15 REPLIES 15
Hi Vlad
What type of integration did you develop with Venafi (for example, REST API, file based)?
Do u have any documents on how you did, It will be very helpful
i'm new to integrations i got requirement . could you please give me some technical document to understand venafi integration with servicenow using rest method or any other
Div4
Kilo Explorer
Hi Vlad,
I am creating a PoC for this integration right now. Do you have any non-confidential IP / documents that you can share with me?
Thanks!
Divya Nanjappa.
nikhil_001
Hi Vlad,
Need your urgent help:
We are also doing integration of servicenow with Venafi. We are hiiting Venafi URL  by POST method (https://------------------/vedsdk/Authorize) to get the API key to create the session and then we will fetch the key by GET method. We are getting the error 'Method failed: (/vedsdk/Authorize/) with code: 400' while hitting it by POST method. Do you have any idea as what could be the possible cause for this.
We have  created an outbound rest and doing basic authentication with the provided user. The user has SDK access also in venafi.
We have created one HTTP headers also Content-Type with value application/JSON.
Thanks & Regards,
Nikhi Jain
