Help configuring the "Process Jira Webhooks" subflow for use in a Flow Designer Service Catalog flow.
MB12
Hi all,
I'm testing IntegrationHub, but having trouble figuring out how to use the "Process Jira Webhooks" subflow in a Flow Designer flow. Is there any detailed documentation on configuring JIRA Spoke flows specifically? My goal is to have a requested item also open a case in JIRA, then have bi-directional syncing with case closure, comments, approvals, etc. I have "Service Catalog" as my trigger, and built the logic within the flow (Screenshot).
JIRA spoke comes with a sample webhook (subflow), but I'm not sure how to this into my flow.
Any help would be greatly appreciated.
Hi everyone, Correlation display and Perspectium Correlation display is the same field or different?
I am not able to find the Correlation display field. I am sharing the screenshot .find_real_file.png
Hi Khozema,
How to find Webhook is triggered or not, I have done the same steps, nothing is happening for me. How to check the logs whether it is working or not.
Thanks in advance
