Help me with some practice assignments to start with in servicenow
awasdivya
I have just started learning Servicenow , please let me know if there is any website/assignment available which i can practice to improve my development skills in SNOW.
9 REPLIES 9
Pradeep Sharma
Hello Divya,
Please refer.
Learning ServiceNow from Scratch and Prepping for the Certification Exam
Get a Developer Instance
Register to get access to personal developer instance free of cost. This instance allows ServiceNow developers to build, extend and integrate new applications.
Self-paced developer training modules are available with the ServiceNow Developer program. These courses are available free of cost. They guide you step-by-step, explaining each module and teaching you how to implement the modules. You get to take a look at their courses for a learn-apply-practice approach. In ServiceNow, practicing learnt knowledge is more effective than just reading the materials.
Thanks a lot Pradeep.
Harish KM
In Community itself developers post a lot of requirments to get the solution you can use the same and try it in your personal instnace. this would also help.
Harish
Hello Author,
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
