Help me with some practice assignments to start with in servicenow
awasdivya
I have just started learning Servicenow , please let me know if there is any website/assignment available which i can practice to improve my development skills in SNOW.
9 REPLIES 9
Prasad Dhumal
Hii,
Are you looking for any more info on this?? If its answered i would request you to please close the thread by marking an answer correct.
- Prasad Dhumal
Deepshikha 3010
Mega Guru
Hii awasdivya,
You can also solve some assigment based on service catalog
S. No
Application
Requirement (User Stories)
1
Service Catalog
Develop or design service catalog item form, which contain below field:
1. Field Name: Requester, Field type: Reference
2. Field Name: Hardware Requirement, Field Type: Radio Button)
  Options are as mentioned below:
·                       Laptop
·                       Desktop
·                       Mouse
·                       Keyboard
3. Field Name: Manager, Field type: Text Box (Read only field)
4. Field Name: Description, Field type: Text Box
2
Service Catalog
In the above requirement (S. No 1) when user selects Laptop then below field will display to him which should be mandatory:
Field name: RAM, Field Type: Dropdown
·                     250GB
·                     500GB
·                     1TB
3
Service Catalog
In the above requirement (S. No 1) when user selects Desktop then below field will display to him which should be mandatory:
Field name: Screen Size, Field Type: Dropdown
·                     14””
·                     15.6””
·                     17””
·                     19””
4
Service Catalog
In the above requirement (S. No 1) Manager field should be read only and should automatically populated with requester manager name. Means when you select the requester then manager name of that requester needs to be populated in that field.
5
Service Catalog
Now the form is created above right. The most important is service catalog transition flow or workflow. In this requirement you have to design the workflow for the created service catalog item:
Workflow Transition should be, after user submits the form or user requested for the above service catalog item, then workflow transition should be:
1. Should move for approval to the requester manager mentioned in form.
·                     If approved by manager then one task has been attached for fulfillment and it should be assigned to any assignment group.
·                     If rejected by manager then item or request is closed rejected.
2. When the task is assigned to assignment group as mentioned above. Then, If the task is closed complete then requested item status should be displayed as completed and if the task is closed cancelled then requested item status should be displayed as closed cancelled.
In both the cases above either cancelled or completed email notification to requester should be triggered stating about the exact status.
I have solved this Assigment If you need any you can ask here
Deepshikha Pandey
please mark as correct or mark as correct if answer is appropriate
Hi Deepshika,
I am a beginner to servicenow, Could you please help me with the assignment you posted here.
Thanks!
May i get more real time work assignments regarding servicenow developer job.
Hi @sabaanjum2
1.Data has to be captured on Dispatch task UI in 2 separate date fields under “Asset dispatch date” and “Asset received by user on”. One field is when asset is handed over to courier company and other field is when asset is delivered by the courier company to the user This will be applicable to all catalogs with dispatch task and will be implemented globally.
Requirement-
2- These field should be available only on Dispatch task.
3 “Asset dispatch date” fields to be mandatory before agent close the task
4 “Asset received by user on” to be mandatory on before agent close the task
2.
Modification in change form for removal of attachment during give right to as assigned to Assigned to person & Change Manager
Requirement Description: Assigned to person & Change Manager to have rights to remove documents being attached on a Change/Ctask Form
Condition:
Change Category – abc & xyz
Type of Change – All
State – New & Rejected in Assess state.
Who - Assigned to person & Change Manager should have access to remove attached documents
3.
We need to need option to relate existing KB , SR, Change based on change category
TIS: On Related Item tab, need option to relate existing KB , SR, Change
TAS: On Related Item tab, need option to relate existing Change, KB
4.
Group must not have an inactive Member_V
5.
Remove inactive user grom group_V1
6.
CMDB ci value based on Dispatch team: asset deployment to user
Onboarding Task - asset/accessories Issuance:  Restriction of CMDB values for asset issuance status reason in SC Task form
discovery source is Asset assurance status reason.
