Help with splitting an array only on first split
Baggies
I have a script that take a value from a text variable, and splits it into an array. It works fine..except, I want the firat array to go into the first text variable, and any subsequent arrays to go into a second text variable.
So, if I get the value from VarA, I want to split it, and push it to  VarB and VarC
If the user enters AAA BBB CCC DDD EEE in VarA
VarB shows AAA
VarC shows BBB CCC DDD  because I don't have enough arrays defined.
If the user enters AAA BBB  in VarA
VarB shows AAA
VarC shows BBB undefined undefined  because I only have two arrays - anything extra is undefined
What I would like to see is:
VarA = AAA
VarB = anything that come after the first split, no matter how many subsequent splits there are.
Many thanks for all replies.....Mark S.
Script is:
var full_name = g_form.getValue('VarA');
var array = full_name.split(" ");
var firstname1 = array[0];
var lastname2 = array[1];
var lastname3 = array[2];
var lastname4 = array[3];
g_form.setValue('VarB', array[0]);
g_form.setValue('VarC', lastname2 + " " + lastname3 + " " + lastname4);
This works just fine now. Many, many thanks!! This is the finished script:
var full_name = g_form.getValue('account_display_name');
var x='';
for(var i=1;i<firstname1.length;i++)
x=x+' '+array[i];
g_form.setValue('u_first_name', array[0]);
g_form.setValue('u_last_name', full_name.split(array[0])[1].trim());
g_form.setReadOnly('u_first_name', true);
g_form.setReadOnly('u_last_name', true);
11 REPLIES 11
var x='';
x=x+' '+array[i];
Abhinay Erra
Please mark my response as correct. You CANNOT mark your response as correct. We work on the community for the credit.
