Help with the below Business rule
Options
09-19-2023 10:51 PM
Hi All ,
I am using the below script in one my function in my Business rule , the entire script is written in the function
function change(){
if(task == 'change_request'){
var changeSysId = current.document_id ;
var assignedto = current.approver.sys_id.toString();
var CR = new GlideAggregate('change_request');
CR.addEncodedQuery("type=Normal^sys_id=" + changeSysId + "^assigned_to=" + assignedto+"^ORrequested_by="+assignedto);
CR.addAggregate('COUNT');
CR.query();
var count = 0;
if(CR.next()){
count = CR.getAggregate('COUNT');
if(count>0) {
return false ;
else {
return true ;
else {
return false ;
and I am callling the function in the below way
var isNormal = change();
I want to now want to trigger an event == approve.insert
I want to utilize function return to trigger or not trigger the approval.insert event , if the conditions in my function are true it should trigger event approve.insert
I wan to to build the logic for above statement in the below code :
if (current.state.changes() && current.state == 'requested') {
var event = "approve.insert";
if (req)
event = "req.approve.insert";
else if (tsk)
event = "tsk.approve.insert";
gs.eventQueue(event, current, gs.getUserID(), gs.getUserName());
var cmt = getComment(isFD, getApproverUserName(current.approver), "Approve");
updateTask(current, cmt);
Can anyone help me to fix this logic ?
Options
09-19-2023 11:13 PM
Could you please provide Error. Try to add gs.logs in script so you will get to know where is breaking
