Hide Module based on role
srujana2
Hi all,
I want to hide some modules under Self Service application in filter navigation based on role.
Here in filter navigation I want to hide above modules under self service application for specific role.
For other users(except specific role) I want visible these modules.
How to achieve this..
Ankur Bawiskar
@srujana
You can control which module can be shown to which role
But not the other way round
So you can create query business rule on sys_app_module table that would only run for these role users and restrict those 3 modules and show all others
Condition:
!gs.hasRole('admin') && gs.getSession().isInteractive() && gs.hasRole('roleName')
Script:
	    current.addEncodedQuery('application=08771d0cc0a8016401f604303b94b999'); // give the sys_id of the application menu here
		current.addQuery('title', '!=','Business Applications');
		current.addQuery('title', '!=', 'Field Service Catalog');
		current.addQuery('title', '!=', 'Knowledge');
})(current, previous);
14 REPLIES 14
@srujana
Did you get a chance to check on the solution I shared?
Hi Ankur,
I tried with your code it is not working..when i Impersonate that specific role users, module is visible to them..
Thanks..
It should work fine as similar was implemented earlier
please share the BR conditions and script
HI,
When to run: before,query(tried with after also)
Thanks..
when to run should be Before Query
Did you try adding logs in that BR
