‎09-06-2022 12:39 AM
Hi Everyone,
I have created a UI macro to open Teams chat. Need to hide this UI macro based if the field value is empty. I have written something like below, however its not working .
Can anyone suggest how I can acheive this.
<j:jelly trim="false" xmlns:j="jelly:core"
xmlns:g="glide" xmlns:j2="null" xmlns:g2="null">
<a class="btn-default;" id="${jvar_n}" onclick="invokeChat('${ref}');">
<img src="teams.png" width="30" title="Teams Chat" alt="${gs.getMessage('Click to open Teams chat')}" />
</a>
<span onChange="onChange('${ref}')"></span>
<script>
function onChange(element, original, changed, loading) {
var visibility = 'visible';
var sysID = g_form.getValue('caller_id');
if (!sysID)
visibility = 'hidden';
var e = gel('${jvar_n}');
e.style.visibility= visibility;
function invokeChat(reference) {
var prefix = 'https://teams.microsoft.com/l/chat/0/0?users=';
var firstname = g_form.getReference('caller_id').first_name;
var user = g_form.getReference('caller_id').email;
var subject = '&amp;message=Hi ' + firstname + ', this is regarding your Incident ' + g_form.getValue('number') + ': ' + g_form.getValue('short_description');
var w = getTopWindow();
var url = prefix + user + subject;
w.open(url);
</script></j:jelly>
Thanks in Advance.
Abdul
‎09-09-2022 02:23 AM
OK here are some thoughts:
- I would fetch the necessary data from the backend in an evaluate tag and not work with "getReference" on client side (saves server calls and gives a better user experience).
I also like to do everything possible on server side and only what is absolutely necessary on client side. These are security considerations, since the server side cannot be manipulated, but the client side can.
I tried to put (excessive) comments in my code so you can understand everything.
The disadvantage of this solution is that this UI macro does not react to changes when the caller_id field is emptied or filled (until it gets saved, then the ui reloads anyways). If this is desired the UI macro would have to be changed again and everything done in the client side and then from an on-change client script a corresponding function in the ui macro would have to be called for recalculation. It depends on your use case, generally the caller is set when the incident is created and does not change anymore.
The following code is my version of how I would solve it currently. There is not one way. If you have any questions I am at your disposal.
xmlns:g="glide"
xmlns:j2="null"
xmlns:g2="null">
<!-- ********** Server Stuff ************************************************************************************** -->
<!-- Check if the caller_id field is not empty and save it into a variable -->
<j2:set var="jvar_caller_available" value="$[Boolean(!current.caller_id.nil())]" />
<!-- Set the caller first name variable if the caller is available (using the variable jvar_caller_available) -->
<g2:evaluate var="jvar_caller_first_name" jelly="true">
var jvar_caller_first_name = '';
if(jelly.jvar_caller_available){
jvar_caller_first_name = current.caller_id.first_name.getDisplayValue();
jvar_caller_first_name;
</g2:evaluate>
<!-- Set the caller email variable if the caller is available (using the variable jvar_caller_available) -->
<g2:evaluate var="jvar_caller_email" jelly="true">
var jvar_caller_email = '';
jvar_caller_email = current.caller_id.email.getDisplayValue();
jvar_caller_email;
</g2:evaluate>
<!-- Set the teams url variable if the caller is available (using the variable jvar_caller_available) -->
<g2:evaluate var="jvar_teams_url" jelly="true">
var jvar_teams_url = '';
var subject = '&message=Hi ' + jelly.jvar_caller_first_name + ', this is regarding your Incident ' + current.number.getDisplayValue() + ': ' + current.short_description.getDisplayValue();
jvar_teams_url = prefix + jelly.jvar_caller_email + subject;
jvar_teams_url;
</g2:evaluate>
<!-- ********** Client Stuff ************************************************************************************** -->
<!-- Check if the caller is available or not -->
<j2:if test="$[jvar_caller_available]">
<!-- Caller field is available, display the teams anchor button -->
<a class="btn-default;" href="$[jvar_teams_url]" target="_blank">
</a>
</j2:if>
<j2:if test="$[!jvar_caller_available]">
<!--Caller field empty, we just want to do nothing :)-->
</j2:if>
</j:jelly>
‎09-09-2022 02:34 AM
this link has the solution
Hide / Show UI Macro on Case Form based on field data
‎09-10-2022 06:05 AM
Did you get a chance to check the link I shared yesterday?
‎09-11-2022 07:17 AM
I did tried that, and I'm not able to make it.
Jelly:
<style>
.hide_hosted_asset_flag {
visibility: hidden;
position: absolute;
left: -1000px;
.show_hosted_asset_flag {
visibility: visible;
background-position: 50% 7px;
</style>
<g2:evaluate var="jvar_caller" jelly="true">
var caller = '';
caller = current.caller_id.getDisplayValue();
if(caller != ''){
caller="true";
caller;
</g2:evaluate>
<j:if test="${jvar_caller}">
</a>
</j:if>
<script>
w.open(url);
</script></j:jelly>
Here if statement not working.
Client Script:
if (!newValue) {
// Hide the UI Macro
var elementToShowOrHide = 'teams_chat';
var myMacro = $(elementToShowOrHide);
myMacro.style.visibility = "hidden";
myMacro.style.position = "absolute";
myMacro.style.left = "-1000px";
g_form.getReference('caller_id', showHideMacro);
function showHideMacro(caller_id) {
// Get the macro
//Check for asset hosted status
var email = caller_id.email;
if(email != ''){
// Show the macro
myMacro.style.visibility = "visible";
myMacro.style.position = "static";
// Hide the macro
I got below error
‎09-11-2022 11:17 PM
The error gives you a pretty good hint where the problem is 🙂
This line in your client scripts seems strange to me:
I guess you wanted to get the JQuery object for this DOM object. I think you need to use $j in a client script to access JQuery. And you also need to make sure that the field "isolate_script" is set to "false" in order to access the DOM at all.
Try this line of code (unfortunately, I could not test it due to my PDI being offline):
var myMacro = $j(elementToShowOrHide);
Another small suggestion: Why do you save the string "teams_chat" in a variable? I would definitely do that if I would use it more than once. But in your code example you only use that string once, so why not just write it directly?
var myMacro = $j('teams_chat');
I like to make guard clauses to not run into errors:
if(!myMacro){ return; }
//do all the stuff you want to do if the script found the DOM object.
