Hide variable when item is part of an order guide
Ellie5
Does anyone have an idea how can hide a variable if the catalog item is completed as part of the onboarding order guide.
I only need to display the variable when the catalog item is used standalone.
All ideas greatly welcomed!
I just realized that probably doesn't make sense if you don't have the variable/set on the OG.  In the variable set in the Catalog Item you can uncheck the 'Visible on Guides' box so that the variable does not appear when the Catalog Item is spawned from an Order Guide
You are welcome!
Connect with me https://www.linkedin.com/in/brad-bowman-321b1567/
Abhishek_Thakur
Hello @Ellie5 ,
You can configure the catalog UI policy to achieve this requirement.
Please mark my answer as accepted solution and give thumbs up, if it helps you.
Abhishek_Thakur
Hello @Ellie5 ,
You can configure the UI policy for the catalog item which is part of order guide. Adding snapshot for better visibility.
Please accept my answer as accepted solution and give thumbs up, if it helps you.
Abhishek Thakur
Thank you for you support with this but Brad had the perfect solution.
