Hide variables from Portal
Cat
Hi all,
I'm trying to do something that seems simple, but for the life of me, I can't get it to work.
I have a couple of variables that I have only visible in the Catalog Task and it is hidden in the Request item and Portal.
When the variable is filled in in the sctask, it doesn't appear in the request item. However, it appears on the portal. I'm using a Catalog UI policy to make it only visible in the sctask. I also created a Catalog Client Script to hide the variable on the portal using a g_form.SetVisible false
I feel like I've done everything I can, but as soon as the variable is filled in, it shows up on the portal!
Does anyone have any ideas of what I am missing?
Thanks for any help!
@Cat
catalog UI policies or catalog client scripts don't work on the ticket page.
So showing/hiding based on some condition doesn't work there.
If you want to hide some variables then you can uncheck this "Visible on Summaries"
💡 If my response helped, please mark it as correct and close the thread 🔒— this helps future readers find the solution faster! 🙏
9 REPLIES 9
@Cat
where on portal? which page?
share screenshots for better help
It's in the portal when the client views the ticket they submitted:
@Cat
This did it! Thank you!
Sarthak Kashyap
Hi @Cat ,
Can you please check the client script if any client script work on UI Type is desktop and doing setVisible("field1", false); or setDisplay("field_1", false);
Or working on UI Type portal and doing
setVisible("field1", true); or setDisplay("field_1", true);
Sample Screen Shot
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
