09-22-2025 05:18 AM
09-26-2025 07:02 AM
I remember reading a community post that mentioned if related list Highlighted value for Workspace is in first or second column, it does not work. Moving it to third or later columns in the list makes it work. I am not sure if it is a bug, I replicated in my PDI and behavior is same.
You can try creating a support case if you want it in first or second column.
As per community guidelines, you can accept more than one answer as accepted solution. If my responses helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
09-22-2025 06:56 AM
Sorry I didn't get your question.
In your question you are showing that UX highlighted value is working but it's not working in native.
that's what I informed UX Highlighted value works for workspace only.
For native you need to create field styles
09-22-2025 07:10 AM
No its working in native but not in workspace. I have used ux highlighted values and its not working still
09-22-2025 05:31 AM
Hello @joshmorris
Can you please check this community article, please mark my answer has helpful if it resolves your issue.
https://www.servicenow.com/community/developer-forum/highlighting-field-in-list-form-in-workspaces/m...
09-22-2025 05:58 AM - edited 09-22-2025 06:03 AM
Check your highlighted value conditions configuration for Workspace as there is a conflict in the conditions with same order and could be the cause for it to not work. Adjust the conditions and order and it should work fine.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
09-22-2025 06:02 AM
I did that and it still doesnt work
