Highlighted values
joshmorris
Why do the highlighted values show on native UI but not on workspace.
@joshmorris
I remember reading a community post that mentioned if related list Highlighted value for Workspace is in first or second column, it does not work. Moving it to third or later columns in the list makes it work. I am not sure if it is a bug, I replicated in my PDI and behavior is same.
You can try creating a support case if you want it in first or second column.
As per community guidelines, you can accept more than one answer as accepted solution. If my responses helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
22 REPLIES 22
Well I showed you the screenshots and it exactly matches what you have done. However I did it on sysapproval_approver table
@joshmorris
Can you share in which workspace under which page you are replicating this so that I can mimic same and share the details ?
Bhuvan
Its in SOW and on a change request go to the approvers related tab. I want the approval status to be coloured depending on the value
@joshmorris
See below for details, I have added the highlighted value condition in Application Scope 'Service Operations Workspace Core'
Highlight Value Condition 'State' is 'Requested'
Make sure Highlighted Value Configuration is linked to 'SOW Highlighted Value Config'
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
@joshmorris
Did you get a chance to review this as I believe the information provided should answer your question.
If my response helped to guide you or answer your query, please mark it helpful & accept the solution.
Bhuvan
