How can I change colors on the Process Flow Formatter based on the different values?
marcelorsc
Kilo Expert
I would like to change the green color on the process flow formatter to red for an specific value. Has anyone come across this yet?
Marcelo R. S. Correia
Principal Business Consultant
EMC Corporation
13 REPLIES 13
i replace image in systemui--->images previeas name chevron_past_past but same name i given but it,s showing old image when it past flow.
Requirement
past - red color
curent - green color
future- normal color
where will i place images?
I tried your code , but not working..
Could you please help on this ...
where i have to change modifications
<link rel="stylesheet" type="text/css" href="styles/process_flow_formatter.cssx"></link>
  <tr>
      <td colspan="2" width="100%" nowrap="true">
          <div>
<table cellpadding="0" cellspacing="0" style="width: 100%;border:none;border-collapse:collapse" class="process_flow_formatter" role="listbox">
<tr role="presentation">
    <g2:flow_formatter var="jvar_flows" table="$[${ref_parent}.getRecordClassName()]" current="$[${ref_parent}]" />
                      <g2:evaluate var="jvar_width" jelly="true">
                                    var size= jelly.jvar_flows.size();
                                    if(size)
                                    Math.floor(100/size);
                      </g2:evaluate>
    <j2:forEach items="$[jvar_flows]" var="jvar_flow">
    <g2:set_if var="jvar_step_status" test="$[jvar_flow.getParameter('state') == 'current']" true="step" false="false" />
        <td style="width:$[jvar_width]%" class="process_flow $[jvar_flow.getParameter('state')]" role="option" aria-current="$[jvar_step_status]" aria-selected="$[jvar_flow.getParameter('state') == 'current']">
    <a href="javascript:void(0);" role="presentation" aria-label="$[jvar_flow.getLabel()]">$[jvar_flow.getLabel()]</a>
        </td>
        <td width="16" height="100%"   aria-hidden="true">
    <img style="margin:0; padding:0px;" alt="" aria-hidden="true"
src="images/chevron_$[jvar_flow.getParameter('state')]_$[jvar_flow.getParameter('next_state')].pngx" />
        </td>
    </j2:forEach>
</tr>
</table>
          </div>
      </td>
  </tr>
</j:jelly>
i have uploaded images in UI images
Sumit Suthar
Mega Expert
Update your UI macro for process flow and adding some styles and changing the source for images if required.
System UI -> UI Macro -> process_flow
