How can I Print Bar code Labels
Mark Lanning
Looking for a How to:
Issue: We need to be able to print a Bar Code Label from ServiceNow!
Fields used for Information: Number / Asset Tag / PO / Serial Number
Have been told we will need the following:
1. Able to put in dimensions of label
2. Sequence Numbering for Equipment Tag ( Needs to be 8 digits )
3. Along with Bar Code want Asset Tag and Serial Number to also print on Label
4. Printer Type ( Zebra , Intermec ,Xerox, etc )
Can anyone point me in the right direction!
Mark
Jace Benson
Looking at some things online, looks like this has been solved already.
See: https://github.com/lindell/JsBarcode/
So I thought I'd give it a try.
I'm not sure how you'll solve the dimension issue but with this library it's not that bad.
Steps to recreate;
1.  Create UI Script and copy/paste the library code from: https://cdn.jsdelivr.net/jsbarcode/3.3.20/JsBarcode.all.min.js
2.  Create UI Macro with svg with id you will call later.
3.  Create UI Formatter calling UI Macro name plus .xml
4.  Add UI Formatter to form.
5.  Add onChange script like so to form;
   * Run on load and on change.
	ScriptLoader.getScripts('jsbarcode.jsdbx', function() {
		console.log('onchange');
		JsBarcode("#code128", newValue);
/*		JsBarcode("#ean-13", "1234567890128", {format: "ean13"});
		JsBarcode("#ean-8", "12345670", {format: "ean8"});
		JsBarcode("#ean-5", "12345", {format: "ean5"});
		JsBarcode("#ean-2", "12", {format: "ean2"});
		JsBarcode("#upc-a", "123456789012", {format: "upc"});
		JsBarcode("#code39", "Hello", {format: "code39"});
		JsBarcode("#itf-14", "1234567890123", {format: "itf14"});
		JsBarcode("#msi", "123456", {format: "msi"});
		JsBarcode("#pharmacode", "12345", {format: "pharmacode"});
Then it works onload and onchange.
16 REPLIES 16
UI Macro;
<svg id="code128"></svg>
<!--<svg id="ean-13"></svg>
<svg id="ean-8"></svg>
<svg id="ean-5"></svg>
<svg id="ean-2"></svg>
<svg id="upc-a"></svg>
<svg id="code39"></svg>
<svg id="itf-14"></svg>
<svg id="msi"></svg>
<svg id="pharmacode"></svg>-->
</j:jelly>
Formatter:
Adding it to the form, right click configure form layout;
Hi Jace,
I tried implementing the same but it's not working. It shows blank.
This post is very old.  I verified it all still works.  Can you hit me up on twitter dm or sndevs slack and I'll help you out...
heres the parts
UI Script
client script on [ticket] (choose your own table)
Macro
Formatter
form layout
form.
Vijaya Aditya V
Hey Jace,
i did the same whatever you mentioned but it is not working for me.
Can you help if you can do something on it
whenever added in the layout it shows as blank space.
