How do I cancel an incident from ServicePortal and how to change to Resoved without error?
ayano
Giga Guru
I don't see the option to cancel.
Also, when I try to Resoved, I get an error.
Please tell me the solution in as much detail as possible.
16 REPLIES 16
@ayano
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
Hi Ankur,
Thank you for many links.
There is too much information and I don't know which one to apply.
I would be grateful if you could only tell me the script to show the cancellation options.
Thanks and Regards,
Hi Ayano,
You will need to fill the Mandatory fields before you proceed with Resolving. Like" Resolution Notes".
Sandeep
Hi Sandeep san,
I want to fill in as few fields as possible because the customer fills in.
Is it possible to solve the problem by skipping those inputs or letting them be automatically entered?
Thanks and Regards,
