How to access a variable inside a variable set using Client script ?
DD18
Kilo Explorer
I am trying to access a variable of a variable set using an On_change client script but not sure about the steps.
Var set name : on_behalf_of
Var name : caller_id - which refers to a table user_info
Tried using - var clrID = g_form.getValue('variables.caller_id'); but I could see an empty alert box when I try to print clrID . Attached the same for reference. Any idea would be useful.
Thanks in advance.
Namrata Khabale
Giga Guru
Hello DD,
 When using an onChange() catalog client script, it is linked to a particular variable instead of a field. Use the following syntax to obtain the value of a catalog variable. Note that the variable must have a name. Replace variable_name with the name of the variable.
g_form.getValue('variable_name');
If my answer helps you Mark it as Helpful and Correct.
Namrata Khabale.
Sumit Suthar
Mega Expert
Hey,DD
To access a variable of a variable set using an On_change catalog client script you can use the variable name.
g_form.getValue('varible_name');
for example:
var clrID = g_form.getValue('caller_id');
alert(clrID);
Indrajit
Mega Guru
Hey DD,
try this below code,
alert(clrID);
it will show you the caller id value in alert box.
Please Mark Correct and Helpful if it is useful.
Indrajit.
