How to add bulk users in a particular assignment group in servicenow
Nikhil kumar ma
I have to add around 150 users in a particular assignment group with the help of import set in ServiceNow.
Please help me in how to do that with the help of import sets.
Thanks and regards,
Nikhil
MattSN
Ideally ServiceNow would include a CSV upload UI action on the sys_user_group.do page but it does not exists at this time.
For anyone that may come across this and is looking for a simple add hoc method, you can do this with a fix or background script. This example works in PDI and will add the 3 mentioned users to the built-in "LDAP Admins" group.
// Define the list of email addresses
var emailAddresses = [
    'abraham.lincoln@example.com',
    'abel.tuter@example.com',
    'fred.luddy@example.com'
// Specify the group name or sys_id
var groupName = 'Your Group Name'; // Replace with your group name
var groupSysId = 'dc0db135c332010016194ffe5bba8f23'; // You can also use the group sys_id if you know it
// Find the group record
var group = new GlideRecord('sys_user_group');
var groupFound = false;
if (groupSysId) {
    if (group.get(groupSysId)) {
        groupFound = true;
        gs.error('Group not found with sys_id: ' + groupSysId);
    group.addQuery('name', groupName);
    group.query();
    if (group.next()) {
        groupFound = true;
        gs.error('Group not found: ' + groupName);
// Loop through the email addresses and add users to the group if the group is found
if (groupFound) {
    emailAddresses.forEach(function(email) {
        var user = new GlideRecord('sys_user');
        user.addQuery('email', email);
        user.query();
        if (user.next()) {
            var userInGroup = new GlideRecord('sys_user_grmember');
            userInGroup.addQuery('user', user.sys_id);
            userInGroup.addQuery('group', group.sys_id);
            userInGroup.query();
            if (!userInGroup.next()) {
                var groupMember = new GlideRecord('sys_user_grmember');
                groupMember.initialize();
                groupMember.user = user.sys_id;
                groupMember.group = group.sys_id;
                groupMember.insert();
                gs.info('Added user ' + user.user_name + ' (' + email + ') to group ' + group.name);
                gs.info('User ' + user.user_name + ' (' + email + ') is already in group ' + group.name);
            gs.error('User not found: ' + email);
    gs.info('Script execution completed.');
    gs.error('Group not found. Script execution aborted.');
