Issue with language in Preferences - instance is not translated
Kasia5
Hello All
I have an issue with translating the instance to the other language. When I got to Preferences and choose the German language hen instance is still in English, means is not translated. When I choose for example French then instance in translated correctly... Maybe you know where I can find the issue?
Thanks in advance for help.
Dr Atul - LNG
Hi @Kasia5
is this an issue after the upgrade? is all language plugin installed or repaired once.
you mean to use this ,,Repair"? I have not done it till now
Yes. Repair and check.
I've repaired but still the same. When I go to preferences and choose German and close the window then instance is still in english and also when I go back to Preferences and language then I see language as English not German as I set before...
