How to add My Groups Work and edited gauges to ITIL homepage?
Megan C
Kilo Expert
This is a 2 part question that I'm hoping has the same answer.
1) If a user removes My Groups Work from the ITIL homepage, where do you find it to add it back?  I can't find it in the Add Content frame.
2) I created a 2nd gauge similar to My Groups Work with an additional filter.  But again, I can't find it to add to the ITIL homepage.
Anirban Roy
Mega Guru
My Groups work is a gauge whose type is 'list' by default. (the type 'list' option is now deprecated.)
I just changed the type to an option - 'count' and the gauge is now selectable
Anirban
11 REPLIES 11
Are they phasing out homepages too then?  Maybe I'm missing it, but not seeing how to add widgets to a homepage either
Hi Megan,
Some steps for your reference:
1. Create a custom widget (I copied the js part from another widget, but it can be replaced):
2. Search in homepage -
I am not sure if there are any plans on deprecating homepages but based on my experience dashboards give richer experience are recommended over homepages.
Anirban
Well I completely forgot about Gauges.  You can still recreate the Gauges as shared reports and add them to the Homepage.
Homepages do seem to be on their way out to be replaced with dashboards.
Gauges are no longer supported, so create gauge from report is disabled it seems. 🙂
I tried in orlando.
I just meant manually recreating reports.
