Notification Option is missing in System Settings for some users
In our instance which is in Paris, the notification tab in system settings is missing for some users. do anyone know the possible reason for that?
Note: It is happening for some users only find_real_file.png
This is a known error. Check the ACL on 'sys_user.notification'. You can refer to the below doc for more detail:
  1. Go to Filter Navigator and search for ACL
  2. On Name, search for sys_user.notification and select the ACL
  3. Please check that the users that should be able to modify either have the correct role or add them to "Requires Role"
  4. If there is a Condition, make sure to modify accordingly to allow required users to be able to modify
  5. If there is a Script, make sure to modify accordingly to allow required users to be able to modify
  6. Click update
Sachin
JerryJ071847183
Tera Sage
It seems to me that someone has made it hidden based on some GLobal UI script.
Check the below link where this has been given how to do it . This will give you idea as where it is configured in your system so that you can deactivate it and make the default setting work again.
LInk 1
LINK 2
Mark my ANSWER as CORRECT and HELPFUL if it helps
Thanks for your reply, We checked the UI Scripts but there are no UI Scripts configured in our instance.
  6. Click update
Sachin
