How to Add or Remove Users in Group.(Using Workflow).
Para5
1. I have created one catalog item "Add Remove client portal Admnistrators".
2.On this catalog item added two variables:
    1.Contact to Add - When the User move in Selected, Automatically add to the 'Client portal group'
    2.Contact to Remove - When User move in Available,Automatically remove from the 'Client portal group'.
3.My requirement is adding or removing users from the 'Client portal group'. I want to implement this using workflow.
   Thank You.
try this
var usersToAdd = current.variables.contact_to_add.toString().split(','); // give correct variable name here
var usersToRemove = current.variables.contact_to_remove.toString(); // give correct variable name here
var rec = new GlideRecord('sys_user_grmember');
rec.addQuery("group.name", "Client portal group");
rec.addQuery("user", 'IN', usersToRemove);
rec.query();
while(rec.next())
    rec.deleteRecord();
for(var i in usersToAdd){
    var rec1 = new GlideRecord('sys_user_grmember');
    rec1.addQuery("user", usersToAdd[i]);
    rec1.addQuery("group.name", "Client portal group");
    rec1.query();
    if(!rec1.hasNext()){
        rec1.initialize();
        rec1.user = usersToAdd[i];
        rec1.setDisplayValue('group', "Client portal group");
        rec1.insert();
regards
14 REPLIES 14
Hi Ankur,
Thanks for response
var grpId = current.variables.u_existing_group;
//set the group fileds empty
var gr = new GlideRecord('sys_user_group');
gr.addQuery('group',grpId);
if(gr.next()){
    gr.parent = '';
    gr.default_assignee = '';
    gr.type = '';
    gr.active = 'false';
    gr.update();
//Remove group members
var grRemoveMember = new GlideRecord('sys_user_grmember');
grRemoveMember.addQuery('group', grpId);
grRemoveMember.addQuery("user", 'IN', grpId);
grRemoveMember.query();
while(grRemoveMember.next()){
    grRemoveMember.deleteRecord();
The below fields are reference fields
gr.parent = '';
    gr.type = '';
Could you please suggest where  i did mistake
@Brahmi Pandla
Can you post a new question for this and share the script and tag me there as this is an old thread?
Hi Ankur
I am trying to delete the group members and set the group values empty with below workflow run script
but not working
// set the group fileds empty
if(gr.next()){
    gr.parent = '';
    gr.type = '';
    gr.update();
//Delete group members
grRemoveMember.addQuery('group.name',Test13025896);
@Brahmi Pandla
