How to attach article on RITM or SCTASK based on catalog item
Harsha Reddy
Hi Community,
How we can attach the articles automatically on RITM or SCTASK form related link based on catalog item. How can we achieve this can you please any one help me on this.
Thanks in Advance,
Harsha Reddy
@Harsha Reddy
I found it
BR: After Insert on sc_req_item
Script:
	// Add your code here
	var gr = new GlideRecord("m2m_kb_task");
	gr.addQuery("sc_cat_item", current.cat_item);
	while(gr.next()) {
		var rec = new GlideRecord("m2m_kb_task");
		rec.initialize();
		rec.setValue("task", current.sys_id);
		rec.setValue("kb_knowledge", gr.kb_knowledge);
		rec.insert();
})(current, previous);
9 REPLIES 9
so knowledge articles are attached to catalog items.
those you want to see under RITM
you can use this script in after insert BR on RITM table
1) query sc_2_kb with catalog item and iterate and insert record into the related list table
Hi Ankur,
Can you please explain how to write BR?
I am not able to find the related list of Attached knowledge on RITM form
Is that a custom one?
@Harsha Reddy
I found it
Script:
	while(gr.next()) {
		rec.initialize();
		rec.insert();
@Harsha Reddy
If my response helped please mark it helpful as well.
