How to autopopulate a field value based on same field value present on a different table ?
1_DipikaD
I want to  auto populate a field value based on same field value present on a different table. As shown in the below picture P records are lnked to t record . We create  records clicking on NEW button on related list of  record . I want to auto populate the field value of  name field on  record at the time while clicking on New button. I  can't find any UI action exists for this . But when I click on ' i ' button besides the name (Reference field) field on   form , it redirects to that record . Could you please suggest how to approach this ? Please let me know if you need more info .
Thank You
@1_DipikaD
as you can see the i icon is seen means the value is getting populated.
which field in main table is marked as Display=true?
Does that field have value in it?
16 REPLIES 16
@Ankur Bawiskar  No it's not populating .
@Ankur Bawiskar  Below ss taken recently . I think it's taking the value but not showing on the form as the mandatory symbol is greyed and not in red .
Good catch, maybe look if any ACL is preventing read access.  Check via Access Analyzer.
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution so others can benefit as well.
Hi @miftikhar20 ,
Checked access analyzer but there is no issue for blockage for that field.
@1_DipikaD
