09-12-2025 05:24 AM - edited 09-13-2025 12:29 AM
I want to auto populate a field value based on same field value present on a different table. As shown in the below picture P records are lnked to t record . We create records clicking on NEW button on related list of record . I want to auto populate the field value of name field on record at the time while clicking on New button. I can't find any UI action exists for this . But when I click on ' i ' button besides the name (Reference field) field on form , it redirects to that record . Could you please suggest how to approach this ? Please let me know if you need more info .
Thank You
09-12-2025 06:33 AM
as you can see the i icon is seen means the value is getting populated.
which field in main table is marked as Display=true?
Does that field have value in it?
09-12-2025 11:27 AM
Yes, you are right as I click on i icon it's redirecting me to the expected record but it is quite strange for me the field value is not visible on form .
Also couldn't get your 2nd point on your previous comment - which field in main table is marked as Display=true? . Could you please elaborate, I will check according to that ?
Thank You
09-12-2025 08:47 PM
the main table has which field marked as Display=true?
whichever field is that will be populated and show when you click New button in related list
09-12-2025 11:42 PM - edited 09-12-2025 11:45 PM
@Ankur Bawiskar I have checked in dictionary there is a string field in main table marked as Dispaly = true .
09-12-2025 11:50 PM
@Ankur Bawiskar and that is not the project name field , there is an another field .
09-13-2025 12:23 AM - edited 09-13-2025 09:38 AM
@Ankur Bawiskar When I marked display = true for project name I can see the value when clicking on NEW on related list . But thing is when I marked display = true for project name field automatically the display is marked as false for the other string field which was Display = true before . It means either of the fields will be in display = true . If one is true then other one will be false automatically. Some one has changed and did not notice this dependency.
