How to base64 encrypt rest message payload
Hi, i have created a rest post method and invoking it through business rule . I need to encrypt the payload.. how to do it? Is it done in rest message or in business rule or somewhere else?
Please help.
9 REPLIES 9
@Community Alums  - please remove the quotes and try again
r.setRequestBody(encryptedPayload);
Thank you very much. I see the encrypted payload. My concern is the encrypted value is only 20 characters long alphanumeric value and it remains same even if i modify incident fields as request payload input. Is this expected? Or the encrypted payload should change each time and should increase if i include more fields in the request payload?
Do you know this?
@Community Alums  - you can decrypt it and validate, for decrypting use this method:
var encryptedPayload = GlideStringUtil.base64Encode(json_payload);
var decryptedPayload = GlideStringUtil.base64Decode(encryptedPayload);
gs.log(decryptedPayload);
If my answer has helped with your question, please mark it as correct and helpful
Thanks!
Yes, i tried it.. it is showing [Object Object]
I have defined the body as var body={....}
encrypted it
If i send encryptedpayload in r.setrequestBody it will give error 400 unacceptable data.
So I'm stringifying the encrypted payload as
Var stri= JSON.stringify(encryptedPayload)
And now setting this in requestBody as
r.setrequestBody(stri)
So this time I'm getting 200 ok response but the decoded value is same in both cases as [object Object]
@Community Alums  - please try this to log object
JSUtil.logObject(decryptedObject, "decryptedObj");
