How to call fix script from schedule job
gnaresh1222
Hi Team,
Please assist How to call fix script from schedule job
Priyanka_786
Hi @gnaresh1222
Use below code in your scheduled job script. Pass your fix script name in query.
Hope it helps. Kindly mark helpful/ accepted if assists you.
Priyanka Salunke.
Servicenow34
Hello @gnaresh1222 ,
Kindly use below code in the scheduled job.
(function(){
var fixScript = new GlideRecord('sys_script_fix');
fixScript.addQuery('name','fix_script_name'); //pass fix script name
fixScript.query();
if(fixScript.next()){
    eval(fixScript.script);
Hope this helps!
Kindly mark helpful / accepted if assists you.
Thank you!
-O-
Move the code from the Fix Script into and adapt it for a Script Include.
Call a method of the Script Include both from the Fix Script and the Scheduled Job.
I believe the existing responses provide valuable insights. However, running a fix script from a scheduled job might not be optimal. Fix scripts, being server-side on-demand scripts, are susceptible to modifications by other developers. It is advisable to consider executing such scripts from a script include. If feasible, replacing the fix script with a script include is also recommended for better maintainability.
