how to Call UI action in client script
Shruthi2
I have to hide a Ui action on the change form on change of the configuration item. How do I refer to the UI action in the on change client script of the configuration item field.Please help me out
Shruthi.
Hi Shruthi,
Did you set this field to false?
Isolate Script -  false
  • This field is not on form but from list you can make it false
  • by default it is true
  • If that is true DOM won't work
17 REPLIES 17
Hi Shruthi,
I have tried this still it throws an error saying onChange script error: TypeError: document.getElementByID is not a function
Isolate script set to false
Client Script:
var data = g_form.getValue('cmdb_ci');
var agg = new GlideRecord('cmdb_ci');
agg.addQuery('sys_id', data);
// agg.addAggregate('COUNT', 'sys_class_name');
agg.orderBy('sys_class_name');
agg.query();
while (agg.next()) {
var name = agg.getValue('sys_class_name');
//alert(name);
//alert(data);
var link = document.getElementById('8b6441e5db629410a2c89cd5ca9619b2');
return false;
I am unable to disable it
where are you testing it ? native UI ?
writing glide record in client script is not good approach. also i would suggest to avoid DOM as much as possible.
