‎10-05-2020 05:02 AM
I'm writing a business rule on User table, this business rule should execute only if the user is part of a specific group.
Can some one help how to put in Condition in advanced tab. I had a property created with the group Sys id
‎10-05-2020 05:40 AM
Or without toString:
gs.getUser().getUserByID(current.sys_id).isMemberOf(gs.getProperty('name of your property'))
‎10-05-2020 05:20 AM
Hi Kri,
To check the group from your property use:
gs.getUser().isMemberOf(gs.getProperty('name of your property'))
Replace above 'name of your property' with the name of your property between quotes.
Returns true if the user is a member of the group you specified in your property. Returns false if not a member of that group. So with above it will execute (true) for users part of that group.
‎10-05-2020 05:23 AM
Hi Willem,
gs.getUser returns the sys id of logged in user, but I need to check the user whose record is updated is part of the Group
Use:
gs.getUser().getUserByID(current.sys_id.toString()).isMemberOf(gs.getProperty('name of your property'))
Is it logged in user or the user who is getting updated
1) If logged in user then this single line should work in BR condition
gs.getUser().isMemberOf("YOUR GROUP NAME HERE")
2) If for the user who is getting updated then below line should work in BR condition
gs.getUser().getUserByID(current.sys_id).isMemberOf("YOUR GROUP NAME HERE")
