How to check which scripts is running
03-25-2025 01:05 PM - edited 03-25-2025 01:08 PM
I am having a record producer, when I submit it, incident record gets created and the assignment group is getting set automatically. There is no configuration or script I found in record producer.
There might be some BR which is responsible for setting the assignment group. I am not able to see any such BR or Script responsible to set the assignment group
Is there any way where we can check which all scripts ran once the record producer is submitted??
Thanks in advance 😃
03-25-2025 01:55 PM - edited 03-25-2025 01:59 PM
Hi @Mk_snow,
Assignment rules in a way that when a record is created then based on certain field value assigned to is configured . Not in a way that assignment rule is used for record producer.
There can be OnSubmit Client script as well for setting up Assigned To value. Many possibilities so figure it out one by one.
if my response helped then you can “accept the solution” and close the thread.
Rohit
