Options
05-26-2022 09:54 PM
I have 2 arrays. I need to get the users not present in the other array. I am using the below code I am able to get unique users but there are duplicates in it.
var arrCapUsers = ["a","b","c","d","e"];
var arrGrpUsers = ["a","b","c","d","e","f","g","h","i","j","k","l"];
var arrFinal = [];
for(var i=0; i<arrCapUsers.length; i++){
for(var j=0; j<arrGrpUsers.length; j++){
if(arrCapUsers[i] != arrGrpUsers[j]){
arrFinal.push(arrGrpUsers[i])
gs.info("arrFinal:"+arrFinal);
Options
05-26-2022 10:28 PM
then do this ->use diff() method
var arrFinal = [];
var arrayUtil = new global.ArrayUtil();
arrFinal = arrayUtil.diff(arrGrpUsers,arrCapUsers);
gs.info(arrFinal);
Output:
Options
05-26-2022 10:20 PM
Hi Hari,
If your desired output for the above mentioned test case is ['a','b','c','d','e'],
Than please make the following changes in your code.
var arrFinal = [];
break;//add this line
Please mark my answer correct / helpful as applicable.
Thanks and Regards,
Rahul
