How to Copy Problem record Work Notes into Related Incident work notes
chanikya
Not working my BR script
After
Condition: current.work_notes.changes()
var updateInitiatedBy = updateInitiatedBy || current.sys_id.toString();
// Add your code here
if(updateInitiatedBy == current.sys_id.toString()){
gr.addQuery('problem_id',current.sys_id);
while(gr.next()){
gr.work_notes = current.work_notes;
gr.update();
Or you can use the same Business Rule as for Incident Work notes -> simply specify a second variable:
// This Business Rule ensures that if there is a Parent Problem record, which has one or more Incidents records associated to it as Child Incidents or Problem Task(s) -> then, whenever the Work notes of the Problem get updated -> the Work notes of all Child Incidents & Problem Tasks will be updated accordingly with the same text;
// var rec = Child Incident(s);
var rec = new GlideRecord("incident");
rec.addQuery("problem_id", current.sys_id);
rec.addActiveQuery();
rec.query();
while (rec.next()) {
rec.work_notes = "Incident Work note copied from Parent Problem" + ':' + current.work_notes.getJournalEntry(1); // //Choose a text of your own, which suits you;
rec.update();
// var prtask = Child Problem Task(s);
var prtask = new GlideRecord("problem_task");
prtask.addQuery("problem", current.sys_id);
prtask.addActiveQuery();
prtask.query();
while (prtask.next()) {
prtask.work_notes = "Problem Task Work note copied from Parent Problem" + ':' + ' ' + current.work_notes.getJournalEntry(1);
prtask.update(); //Choose a text of your own, which suits you;
})(current, previous);
Best Regards,
Georgi Mavrodiev
IT Consultant
Do IT Wise Bulgaria
You may visit us in our Web Site: www.doitwise.com
29 REPLIES 29
can you please help me in similar task in problem
when we enter work notes in ProblemTasks the work-notes copy into Problem record
Chanikya,
You may use a similar Business Rule but this time, in its script, you will query 'problem_task' table instead of 'incident', and the field: 'problem' instead of 'problem_id'.
Run a test like described and verify the result. Thank you!
Best Regards,
Georgi Mavrodiev
IT Consultant
Do IT Wise Bulgaria
rec.query();
rec.update();
prtask.query();
Best Regards,
Georgi Mavrodiev
IT Consultant
Do IT Wise Bulgaria
here i used to Copy
ProblemTask record of worknotes into   Problem record
PTASK0010004---------} into PRB0040022
PTASK0010005---------}into  PRB0040022
Hello again, Chanikya,
I got your latest request wrongly the first time I red it.
So if you want to move Work notes from Problem Tasks (Child) to Problem (Parent) you will have to create a separate Business Rule:
- table - Problem Task (problem_task);
- When to run: before Update;
- Advanced > Script:
// add a description of the BR;
var prob = new GlideRecord('problem');
prob.addQuery('sys_id', current.problem.sys_id);
prob.addQuery('sys_id','!=',current.sys_id);
prob.query();
while(prob.next()){
prob.work_notes = 'Problem Task: ' + current.number + ' work notes ' + ' : ' + current.work_notes.getJournalEntry(1);
prob.update();
Please have in mind that this is only for a case in which you are using the first Business Rule I wrote you to update work notes of Incident from Problem. The current BR (the second one) will be used to update work notes of Problem from Problem Task.
If you want to ensure that Problem work notes will update child Incidents and also child Problem Tasks while work notes of child Problem Task will update Problem work notes -> then you need to put some additional conditions into both the BRs in order to prevent duplication:
- both BRs will have to have the following line in their Advanced > Condition: current.work_notes.indexOf('###')<0
- also work notes texts in both BR scripts will have to contain ###, for example: 'Problem Task: ' + current.number  + ' work notes ' + ' : ' + current.work_notes.getJournalEntry(1); will be changed to: '### Problem Task: ' + current.number  + ' work notes ' + ' : ' + current.work_notes.getJournalEntry(1);
Chanikya, test the above BR and let me know the outcome.
While testing it, please check if no duplication of work notes appear in the Incident child records and other Problem Task child records. Thanks!
Best Regards,
Georgi Mavrodiev
IT Consultant
Do IT Wise Bulgaria
