05-01-2019 02:12 AM
hi,
i wanna copy URL of attachments into Incident Table field u_url.
My scripts not working....
BR Script: Table: incident before --insert/update
var producer_id = gel('sysparm_item_guid').value;
var gr = new GlideRecord('sys_attachment');
gr.addQuery('table_name', 'incident');
gr.addQuery('table_sys_id', producer_id);
if(gr.next())
current.u_url=gr.location.href;
Or-------------------------
BR Script: Table: sys_attachment before --insert/update
var grr=new GlideRecord('incident');
grr.addQuery('sys_id',current.table_sys_id);
grr.query();
if(grr.next)
var hrf=location.href;
grr.u_url=hrf;
grr.update();
05-01-2019 02:24 AM
Or if its just a list of all sys_attachments you are after:
current.u_url_field_or_something = gs.getProperty('glide.servlet.uri') + 'sys_attachment_list.do?sysparm_query=table_sys_id=' + current.getUniqueValue();
Kind regards,
Mark
05-01-2019 03:09 AM
there are one UI-Page is there.
by using UI-Page -one button Presented in Incident table..so Can i use this script from UI - Page?
05-01-2019 03:07 AM
it is working Great ..!!!..
Thanks a lot MARK...!!!
05-01-2019 03:14 AM
No worries, glad to help.
Please mark this answer as correct if it solves your problem. This will help others who are looking for a similar solution. Also marking this answer as correct takes the post of the unsolved list.
Thanks.
Kind regards,
Mark
05-03-2019 02:05 AM
Thanks.
Kind regards,
Mark
05-03-2019 10:25 AM
Thanks.
Kind regards,
Mark
