how to Create a Database view joining problem_task and Attachments( Sys_attachment) table
Vidya Aeil
To do this I'm trying to create a database view joining the problem_task and Attachments( Sys_attachment) table. Need a report view that displays the count of all closed problem tasks containing attachments, Now how do I filter the sys_attachment table to only show closed problem_tasks? I can see problem_task but how do I know if they are closed.
So I need  to build a database views on this table  sys_attachment AND problem_task. Please give me the some suggestion to this.
Thank you.
Vid
Hi @Vidya Aeil ,
Is the response answers your question? If yes please mark my response as accepted solution and close the thread.
Thank you,
Palani
Thank you,
Palani
palanikumar
Do the following:
  1. Create Database View
  2. Add first table as problem_task with variable prefix as prb
  3. Add Second table as sys_attachment with variable prefix as attach
  4. set condition in second table as below:
             attach_table_name=problem&&attach_table_sys_id=prb_sys_id
Thank you,
Palani
Thank you,
Palani
4.
  1. set condition in second table as below:
This is I need to put in Where clause Right
Thank you.
Vidya
Please us this in the where clause. I tested in my PDI, it is working fine
attach_table_name="problem_task"&&prb_sys_id=attach_table_sys_id
Thank you,
Palani
Thank you Palani .
