How to create a reference field where multiple users can be selected at a time?
Mahendra RC
I have a requirement were I need to create a reference field to selected the Users. I tried to use 'List' type field for this. So when I select the users from this List type field I am able to select single user at a time.
However as per the actual requirement we need to create a reference field where multiple users can be selected at a time. Say if I want to select 20 users then I should be able to select that in single attempt when I click on 'Magnify' icon to select the users.
Can anyone please help me with the solution for this as soon as possible. Please let me know if it is possible OR not?
Thanks in Advance.
Hi Mahendra,
Use a slushbucket
On the left side you will have all the values and on the right hand side the selected values.
Let me know if any queries.
