How to create a request(RITM) through code in an Order Guide in servicenow
11-11-2025 09:51 PM
HI,
I have a requirement where I need to create a Request(RITM) in an Order guide through code. So, I am implementing this code In a BR as per my requirement.
Order Guide Name-Tech support
Catalog items in an tech support Order guide are 1)Application support 2)Cost support
So now in order to create a request in order guide I need to fill these below fields
1)Requested for(variable in Order guide "Tech support")
2)Category(variable in Order guide "Tech support")
3)Application(variable in catalog item "Application support")
4)Description(variable in catalog item "Application support").
So, I need a sample script where I can set values for all the above variables navigating through order guide and catalog items.
11-11-2025 09:56 PM
Hi @sushma123vu ,
To submit request via script, you need to use CartJS API
Please find doc for reference: https://www.servicenow.com/docs/bundle/zurich-api-reference/page/app-store/dev_portal/API_reference/...
Thanks, GP
11-11-2025 10:00 PM
Hello @sushma123vu
You can refer to this article:- Order a Order Guide using script - ServiceNow Community
If this helps you, kindly mark my answer as helpful.
11-11-2025 10:43 PM
Hi @sushma123vu ,
Please check below code
var orderGuideAPI = new sn_sc.OrderGuide();
var orderGuide = orderGuideAPI.getOrderBySysID("sys_id_of_your_order_guide");
var items = [
itemSysID: "sys_id_of_catalog_item_1",
quantity: 1,
variables: {
variable_name_1: "value_1",
variable_name_2: "value_2"
var item = items
orderGuide.addItem(item.itemSysID, item.quantity, item.variables);
var request = orderGuide.submit();
gs.info("Order Guide submitted. Request number: " + request.number);
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
11-11-2025 10:52 PM
HI @Sarthak Kashyap ,
can you also help me with the code of how to set values to order guide variables as it was not mentioned in the above code. Thanks!
