How to create JSON array in following format.
Para5
I have following requirement.
I want Json array such that :
"UserandRoles":[
                            "name":"Abel",
                            "role":"admin"
                            "name":"Abel",
                            "role":"security_admin"
                            "name":"John",
                            "role":"itil"
Script is as below:
var info = [];
var Information = {};
var gr = new GlideRecord('sys_users');
gr.addQuery('sys_id',  usersys);
if( gr.next()){
info.name = gr.name.getDisplayValue();
info.Roles = gr.u_roles.getDisplayValue(); // u_role field contain roles in folllowing format role1, role2, role3....
info .push(Information );
newhand
@Para5
var infoList = []
if( gr.next()){
var info = {}
var user_name = gr.name.getDisplayValue();
var roles_arr = gr.roles.split(','); // u_role field contain roles in folllowing format role1, role2, role3....
for (var i = 0; i < roles_arr.length; ++i) {
info.name = user_name
info.role = roles_arr[i]
infoList.push(info);
Information.UserandRoles = infoList
gs.info(JSON.stringify(Information))
jaheerhattiwale
@Para5 Tried and tested solution.
var mainObject = {
    "UserandRoles" : []
var gr = new GlideRecord('sys_user_has_role');
gr.addQuery('user',  usersys);
while( gr.next()){
    var infoObject = {};
    infoObject.name = gr.user.getDisplayValue();
    infoObject.role = gr.role.getDisplayValue();
    mainObject["UserandRoles"].push(infoObject);
gs.info(JSON.stringify(mainObject));
Please mark as correct answer if this solves your issue.
