How to create Problem task automatically?
Basha4
When we create problem record that time automatically create problem task records
paulmorris
You would do this by creating a Flow in Flow Designer.
Perhaps if you give more specific requirements we can be of further help?
Learn more about using Flow Designer here.
plz tell me the process how we create problem tasks
You create a Flow with a trigger of 'When record is created'.
Then, you create Create Record actions to create Problem Tasks with a parent of the Triggering record.
suvro
You can achieve this using workflow,
Use Create Task activities to create problem task
