How to define shown fields in Related Items
David Stutter
This is my view:
This view is on incident table.
Version: Helsinki
I have no idea how to config the fields.
On the other hand, why does this man have a fancier view than me?
How is "add CI relationship" enabled/disabled   in "Related Items" formatter
David Stutter
Here is your answer:
http://wiki.servicenow.com/index.php?title=Many_to_Many_Task_Relations#Modifying_the_Displayed_Field...
The name of the view is "sys_ref_list".
5.1 Modifying the Displayed Fields
The fields displayed in the Task Relations field and editing interface are defined by the Reference Lookup's list view.
To modify the displayed fields:
  1. Navigate to a form that has a reference to the table whose display values you would like to modify within Task Relations field.
  2. Click the magnifying glass to display the Reference Lookup list view.
  3. Right-click the list header and select the appropriate option for your version:
    • Fuji or later: Configure > List Layout
    • Eureka or earlier: Personalize > List Layout
The selected List layout will be used as the display value for records within the Task Relations field.
Great work, thanks!
Hi @David Stutter,
The link which is provided above is not working, can you please provide the correct link
