How to generate a REQ, RITM and SCTask through flow designer
Priyanka145
I need to create a Service Request record through a flow designer based on some trigger condition.
Along with REQ I also need to get RITM and SCTask through the flow designer for the respective Request.
I am only able to generate REQ through create Request action but RITM and SCTask are not getting triggered.
Please help me how to get all 3 REQ, RITM and SCTask at once through FD or also let me know any other possible way
Hi Priyanka,
Create Flow in flow designer with the following steps:
Create Trigger:
Create your own trigger, here i have shared a Inbound email action trigger:
Create action:
Create task:
Hi Priyanka,
Create Trigger:
Create action:
Create task:
Thankyou , it worked well
Hi Sandeep, I need to trigger a catalog item through a workflow and it should generate req, ritm , sctask I tried and I am only getting ritm and no associated sctask and req are appearing. Could you please guide me with few links or script part for it Thanks
