How to Generic flow using flow designer
09-23-2025 02:23 AM
I am trying to create flow using flow designer
In that i am creating catalog task
I want that the catalog task should take value from catalog definition of catalog item
How can i acheive this
09-23-2025 02:27 AM
Hi @AvinashDubey ,
You can dot-walk in flow designer if needed by using fd_data instead of fix entries.
09-23-2025 02:59 AM
can you please share an example for this ?
09-23-2025 01:08 PM
09-23-2025 02:58 AM
Hi @AvinashDubey ,
You can dot walk to the required fields using data pills or you can also access it using script.
If you are building generic flow and if you have only one task you can use Fulfillment group field available on catalog item, this field can be used to set the assignment group on catalog task.
Anand
