How to get correct CI Class for imported Assets?
braddiamond
Giga Expert
I am importing asset data through a transform map/import set, and am setting my model category (Computer for instance), but yet, the CI that is created is not being set to the Computer class.   It keeps creating a CI with the 'Configuration Item' class.
Any suggestions on what I should be including in my transform to get the CI to create properly?   When we manually create a Computer Asset, the Ci is created correctly, so the Model Category is setup properly.
Thanks!
Brad
Ben,
I wanted to give you an update - we found the issue.   In one of my field mappings, I was asked to populate the CI name based on some other criteria.   Because we did this, the CI was then created before the AssetAndCISyncronizer could run - by then, there was already a blank shell of a CI in the CMDB.
We removed this mapping - and voila!   The CI creates the way it should.
Thanks all for the responses.
ark6
Mega Guru
Hi Brad,
We have the simillar issue.
We are trying to upload asset with the model category as computer, but the CIs are getting created in the cmdb_ci table instead of cmdb_ci_computer.
Please let me know how you have managed to write your transform map
