How to get difference between two dates(Start date and End date) in the scoped application?
J P Rohini
Hi all,
i have tried this code, but dint work out,
var v1 = new GlideRecord('x_252275_video_video_table');
v1.query();
while(v1.next()){
var g1 = new GlideDateTime('start_date');
var g2 = new GlideDateTime('end_date');
var sub = new GlideDateTime.subtract(g1,g2);
gs.info('Testing'+' '+sub);
Output returns in this format:1970:11:21  8:00:54:06
But Output should be in this format: 1 year 11 months 12 days
Thanks in Advance
Any help is appreciated.
Satyanarayana C
Please check if this works for you.
function convertDaysToYearsMonthsDays (diff) {
  var str = '';
  var values = [[' year', 365], [' month', 30], [' day', 1]];
  for (var i=0;i<values.length;i++) {
    var amount = Math.floor(diff / values[i][1]);
    if (amount >= 1) {
       str += amount + values[i][0] + (amount > 1 ? 's' : '') + ' ';
       diff -= amount * values[i][1];
  return str;
var dur = new GlideDuration();
dur.setValue('2018-03-01 07:30:00');
var duration2 = new GlideDuration();
duration2.setValue('2020-06-10 10:35:00');
var answer = duration2.subtract(dur);
gs.info(answer.getDisplayValue());
// get the day part
var gd = new GlideDuration(answer);
gs.info(convertDaysToYearsMonthsDays(gd.getDayPart()));
The function convertDaysToYearsMonthsDays - is taken from internet.
16 REPLIES 16
where we used this script background or BR
Tejas Tamboli
Giga Guru
Hello J P Ramya,
You should add getDisplayValue() to the end of the sub variable.
Refer below code do changes accordingly:
v1.query();
while(v1.next()){
   gs.info(g1);
   gs.info(g2);
   gs.info('Testing'+' '+sub.getDisplayValue());
I hope this will help you.
Mark ✅ Correct if this solves your issue and also mark 👍 Helpful if you find my response useful to you and help others to find information faster.
Tejas
Hello Tejas,
The above code dint work for me,
Actually the output should be 1 year 14 months 1190 days.
Function calDateDiff is not allowed in scope. Use GlideDateTime.subtract() instead and the other point is Function gs.print() is not allowed in scope. Use gs.debug() or gs.info() instead.
var gdt1 = new GlideDateTime("2011-08-28 09:00:00");
var gdt2 = new GlideDateTime("2011-08-31 08:00:00");
var dur = GlideDateTime.subtract(gdt1, gdt2); //the difference between gdt1 and gdt2
gs.info(dur.getDisplayValue());
Output:
2 Days 23 Hours
You can try like this:
v1.query();
while(v1.next()){
   var sub = GlideDateTime.subtract(g1,g2); //the difference between g1 and g2
   var dur = sub.getDisplayValue();
   gs.info('Testing'+' '+dur);
Output:
The output should be 1 year 14 months 1190 days.
For more details you refer below link:
https://developer.servicenow.com/dev.do#!/reference/api/orlando/server/no-namespace/c_APIRef#r_Scope...
Mark the answer as Correct/Helpful based on its impact.
Thanks & Regards,
Tejas
Please refer below code do changes accordingly it will help you:
var startDate = new GlideDateTime("2011-08-28 09:00:00");
var endDate = new GlideDateTime("2013-01-21 08:00:00");
var startYear = startDate.getYear(); //get startYear year
var february = (startYear % 4 === 0 && startYear % 100 !== 0) || startYear % 400 === 0 ? 29 : 28;
var daysInMonth = [31, february, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31];
var yearDiff = endDate.getYear() - startYear;   //the difference between startYear and endYear
var monthDiff = endDate.getMonth() - startDate.getMonth(); //the difference between startMonth and endMonth
if (monthDiff < 0) {
   yearDiff--;
   monthDiff += 12;
var dayDiff = endDate.getDayOfMonth() - startDate.getDayOfMonth(); //the difference between startDate and //endDate
if (dayDiff < 0) {
   if (monthDiff > 0) {
      monthDiff--;
      yearDiff--;
      monthDiff = 11;
   dayDiff += daysInMonth[startDate.getMonth()];
gs.info(yearDiff + 'year' + ' ' + monthDiff + 'months' + ' ' + dayDiff + 'days');
Output: 1year 4months 23days
v1.query();
while (v1.next()) {
   //var sub = GlideDateTime.subtract(g1, g2); //the difference between g1 and g2
   //gs.info('Testing'+'  '+sub.getDisplayValue());
   var startYear = g1.getYear();         //get startYear year
   var yearDiff = g2.getYear() - startYear; //the difference between startYear and endYear
   var monthDiff = g2.getMonth() - g1.getMonth(); //the difference between startMonth and endMonth
      yearDiff--;
      monthDiff += 12;
   var dayDiff = g2.getDayOfMonth() - g1.getDayOfMonth(); //the difference between startDay and endDay
   if (dayDiff < 0) {
         monthDiff--;
         yearDiff--;
         monthDiff = 11;
      dayDiff += daysInMonth[g1.getMonth()];
Tejas
