How to get difference between two dates(Start date and End date) in the scoped application?
J P Rohini
Hi all,
i have tried this code, but dint work out,
var v1 = new GlideRecord('x_252275_video_video_table');
v1.query();
while(v1.next()){
var g1 = new GlideDateTime('start_date');
var g2 = new GlideDateTime('end_date');
var sub = new GlideDateTime.subtract(g1,g2);
gs.info('Testing'+' '+sub);
Output returns in this format:1970:11:21  8:00:54:06
But Output should be in this format: 1 year 11 months 12 days
Thanks in Advance
Any help is appreciated.
Satyanarayana C
Please check if this works for you.
function convertDaysToYearsMonthsDays (diff) {
  var str = '';
  var values = [[' year', 365], [' month', 30], [' day', 1]];
  for (var i=0;i<values.length;i++) {
    var amount = Math.floor(diff / values[i][1]);
    if (amount >= 1) {
       str += amount + values[i][0] + (amount > 1 ? 's' : '') + ' ';
       diff -= amount * values[i][1];
  return str;
var dur = new GlideDuration();
dur.setValue('2018-03-01 07:30:00');
var duration2 = new GlideDuration();
duration2.setValue('2020-06-10 10:35:00');
var answer = duration2.subtract(dur);
gs.info(answer.getDisplayValue());
// get the day part
var gd = new GlideDuration(answer);
gs.info(convertDaysToYearsMonthsDays(gd.getDayPart()));
The function convertDaysToYearsMonthsDays - is taken from internet.
16 REPLIES 16
Hi @Tejas Tamboli  Its not working If End date value Less than Starting date value. Its showing Wrong date
Any update?
Is this answered?
If my answer helped you, kindly mark it as ✅ Correct & 👍Helpful so that others with the same question in the future can find it quickly & close the thread and that it gets removed from the Unanswered list.
Tejas
Ashutosh Munot1
HI,
I always give this example to people which helps you to get difference in days, min, sec,etc.
v1.query();
while(v1.next()){
var firstDT = new GlideDateTime('start_date');
var secondDT = new GlideDateTime('end_date');
var diffTYPE = 'day';
var diff = gs.dateDiff(firstDT, secondDT, true);
var timediff = this._calcDateDiff(diffTYPE, diff);
gs.print(timediff);
//Private function to calculate the date difference return result in second, minute, hour, day.
//_calcDateDiff: function(diffTYPE, seconds){
var thisdiff;
if (diffTYPE == "day"){thisdiff = seconds/86400;}
else if (diffTYPE == "hour"){thisdiff = seconds/3600;}
else if (diffTYPE == "minute"){thisdiff = seconds/60;}
else if (diffTYPE == "second"){thisdiff = seconds;}
else {thisdiff = seconds;}
//return thisdiff;
Ashutosh Munot
Function calDateDiff is not allowed in scope. Use GlideDateTime.subtract() instead and the other point is Function gs.print() is not allowed in scope. Use gs.debug() or gs.info() instead.
Satyanarayana C
  var str = '';
    if (amount >= 1) {
  return str;
// get the day part
