How to get the difference between 2 date fields in scoped application
vasu17
Please help on this ,
i want to get difference between 2 date fields (start and end dates) and populate in duration field for the scoped application by using client script
i have used the script it's worked for global but for the scoped it is not working
here are the scripts both are in same scoped application
Script include:
var DateFormatUtils = Class.create();
DateFormatUtils.prototype = {
    initialize: function() {
calculate: function() {
  return gs.dateDiff(this.getParameter('sysparm_strt'),this.getParameter('sysparm_end'), false);
    type: 'DateFormatUtils'
client script:
function onChange(control, oldValue, newValue, isLoading) {
  var strt = g_form.getValue('start_date');//set this as start date
  var end = g_form.getValue('end_date');//set this as end date
  var ajax = new GlideAjax('DateFormatUtils');
  ajax.addParam('sysparm_name','calculate');
  ajax.addParam('sysparm_strt',strt);
  ajax.addParam('sysparm_end',end);
 ajax.getXMLAnswer(function(answer){
        if(answer != ''){
  //ajax.getXMLWait();
  //var answer = ajax.getAnswer();
  g_form.setValue('duration', answer);
please modify this script if anything wrong for the scoped application
Thanks in advance
Hello @vasu17 ,
It is working on my side. please do exact same script, it would be work.
Enter proper variable names.
Make sure "Applies on target record" & "Applies on Requested items" is True .
Sayali Gurav
Ankur Bawiskar
@vasu17
use GlideDateTime subtract method
Your script include won't get called as it's not client callable
HI @Ankur,
Script include is client callable only, please help on this
Thanks in Advance
Hi @vasu17
The Class in your Script Include was wrongly generated.
It should be looked like below
DateFormatUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
        return gs.dateDiff(this.getParameter('sysparm_strt'), this.getParameter('sysparm_end'), false);
Also make sure you grant the correct user role for this Client Callable Script Include.
Cheers,
Tai Vu
