How to get the variable values in flow designer
Sriram Pusuluri
Hi Team,
I have a flow designer, Once I submit the item, Ritm and sc_tasks are creating.
Now in sc_task short description I want to add one of the variable value in it.
I have added above one in my flow designer Action, this is coming in below way
Below is how my variable values are showing in catalog form
How to do this? Do I need to create any other Action
@Sriram Pusuluri
1 thing to check -> if that variable is select box then why it shows Search Icon
try this other way in script
Also check if there is any space in the variable name
var choiceLabel = fd_data.trigger.request_item.variables.addon_licence_project.getDisplayValue();
return choiceLabel;
20 REPLIES 20
@Sriram Pusuluri
you need to add script by clicking that script icon
@Ankur Bawiskar
I have added below script
and in description
in Task descrption it is showing as empty
@Sriram Pusuluri
is that variable selected in "Get Catalog Variables" flow action?
it should work fine
@Ankur Bawiskar
Yes it is available
@Sriram Pusuluri
did you check if flow variable is getting populated or not?
I am surprised as that variable is Select box then why Lookup icon is shown
