How to Inactivate Reports?
thereseg
We have hundreds out of the box reports that are visible under view Reports. Most of these are for modules we don't use, how can I "inactivate" them.
I don't want to delete them as we might want them in the future or keep historical reports we used. Our "real" reports gets lost in the giant list.
Most items and tickets have an active flag but I can't find one for reports?
I guess one work around is to assign most of the GLOBAL reports to a role that no one has, though that changes the report and you loose traceability.
Also it doesn't help the Admin (which is me).
If this doesn't exit currently how do one suggest this for the next version?
Kalaiarasan Pus
What if you change the User field of entries in 'sys_report' table to some ID ? That should be nearly close to disabling it and you would still have them in instance if needed.
