How to insert value into Prompt box in ATF (Automated Testing Framework) ( is it possible OR Not )
chanikya
when i click on UI action it will displays one Prompt box for user input, Now how can i pass value into Prompt box  In ATF.
Any suggestions recommended .
Ankur Bawiskar
@chanikya
Javascript prompt boxes, alert and confirm box cannot be tested via ATF
20 REPLIES 20
No you can write the code in client side script
which one i have to select
Click the UI action.
i think we don't have chance to mention script there, by using this hopfully we only access Buttons
Hi Chanikya,
Did you get workaround for this i.e. prompt box input in ATF?
If yes then what steps were taken
