‎04-18-2022 05:24 AM
Hello Experts,
I need help in below script;
arr = ['sysid,'sysid'];
I want to create a for loop and get each sysid to be passed in a gliderecord and add each value as part of encodeded query as well,
Need help in building it
Change Management
Incident Management
‎04-18-2022 07:40 AM
by iterating every sysId you want to fetch the child
do like this
var arr = ['sysid1','sysid2'];
var child = [];
for(var i in arr){
var gr = new GlideRecord('table');
gr.addEncodedQuery('parent!=NULL^active=true^parent=' + arr[i]);
while(gr.next()){
child.push(gr.sys_id.toString());
‎04-18-2022 07:31 AM
Hi Ankur,
thanks for the response, but I need to iterate through each sysid of array, and not search only single match from array.
do like this
var child = [];
for(var i in arr){
while(gr.next()){
‎04-18-2022 07:57 AM
The previous example was better. It was searching the entire array all at once using parentIN, which should satisfy the requirement of getting all items where the sys_id is listed as the parent. one query is better than array.length queries.
This can be simplified using a glidequery, too:
var child = new GlideQuery('table')
.where('active', true)
.where('number', '!=', 'NULL')
.where('number','IN',arr)
.select()
.map(function(e) {
return e.sys_id;
.toArray(100);
gs.info(child)
example returns
"9e7f9864532023004247ddeeff7b121f",
"552c48888c033300964f4932b03eb092"
‎07-18-2022 08:04 AM
Ankur again for the win. I had:
for (var i = 0; i < array.length; i++)
and it wasn't working. I found this post and, cross checking with the comments here changed my code to:
for (var i in arr)
and, like magic, it all started working.
I didn't ever really understand what that first statement was actually saying but it's all a little clearer now.
Don't go away though. I might need you.....;-)
