How to make dependent between 3 variables in record producer
yugesh k
How to make dependent between 3 variables in record producer?
I have created 3 variable
1) Country
2) Company
3) sub company
 I select country "IND" it need to show companies under IND & then selected company "A" it need to show sub companies under  A.
Thanks & Regards
yugesh k
Hi Gaurav,
Making dependent through script is like hardcoded, I'm looking for some other way achieve.
Thanks for your response.
@yugesh k
I don't think so there could be another way unless you have a separate table created for the same.
I hope the other folks can help you with this.
you dont need to hardcode , you can create a sys_propery with json object which returns the encoded query.
box1 : 'encoded query1',
box2 : 'encoded query2',
box3 : 'encoded query3'
☑️ Please mark responses as HELPFUL or ACCEPT SOLUTION to assist future users in finding the right solution....
LinkedIn - Lets Connect
